Old 02-23-21, 05:56 PM   #17
pinballlooking
pinballlooking's Avatar
I did the home Hydro test. Filled it completely with water. Then used pressure washer to pressurize it.
I pressure tested it to 310 psi. it held good. With this test I would feel good at even 175 psi but it probably move it down to 155 psi.
Knowing the pressure washer limitation not going any higher than 250 psi once you let off the trigger. I made it so I could watch the gauge as I pressurized it. When I saw it 300 I let off.
No leaks good to go.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
