Old 02-04-21, 10:00 AM   #11
pinballlooking
pinballlooking's Avatar
The check valve was the wrong size for the top pipe. I ordered the correct one. I hope to do the home hydro test in next couple days.
The motor sounds really good now much quitter. I will take a new video of it running once the check valve comes in.
I ordered two 3/4" check valves so I can plum the two compressors together. That way I can run one or the other or both at the same time.
I might run a bypass to the check valve on the old compressor that way I can have extra storage.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
