Old 10-23-13, 11:06 AM   #2
I don't think you'll kill your furnace if you close off other vents to get more hot air over that way. I've done this to quite an extent in my house (cause my vent system is really pretty screwed up), and my 15 year old furnace is happily chugging away. That is why we have the adjustable heat registers, so you can tweak and balance air flow to each room.
If that doesn't work, I'd probably look into one of those inline fans to help push more heat into the room.
Other than that, are there any noticeable air leaks or anything else you can do to stop the room from cooling down as fast?
