Old 08-24-11, 10:00 AM   #11
S-F
You Ain't Me
S-F's Avatar
Get a pressure tester so you can verify for yourself that it can push out 3.5 Lbs. Make a test box. Build a 16" O.C. box out of 2x4's. Cover the back with OSB or something and mesh off the front. Make it tall enough to give you a sense of how filling it all up works. I'll be easier to tear the cellulose out of a bad test box than an entire cavity.
The Following User Says Thank You to S-F For This Useful Post:
AC_Hacker (08-24-11)
