Old 05-21-19, 05:36 PM   #1
Default Help! Leaky Hot Water Tank problem!
My Electric hot water heater / PVsolar+heat pump Storage tank is leaking.
It seemed to be leaking around the Anode port.
I pulled out what was left of the Anode and ordered a replacement.
https://www.amazon.com/gp/product/B0006JLSO2
Anode rod
Made from aluminum
42" long
5/8" outside diameter
3/4" -14 NPT
Standard stuff. Installed it using Rectorseal 23631
https://www.amazon.com/gp/product/B0002YPAFY
It leaked, so I tried again. Still leaked.
Cleaned it up and tried Teflon tape/PTFE and it still leaked (very slow).
Cleaned it up and tried using 8 turns of 1" wide PTFE, it's still leaking!
Since the water heater is about 5 years old, I'm thinking about using
some kind of Cold Steel epoxy to permanently seal the Anode,
since the tank is already very near end-of-life..
Please impart some expert advice!
Thanks,
Rich
