Old 10-18-16, 10:19 PM   #3
where2
DIY Geek
Go with what Jeff said about a locating a short 240V unit. If you're concerned about running out of warm water, run the 19 gallon unit at a higher base temp than you were running the 30 gallon gas unit for the few months that you need to rely on this unit. You mix hot with cold to get a 1.2gpm or 1.5gpm stream out the shower head.
If your cold water is coming out of the ground at 40°F, it must feel like what we get out of the ground at our property in Northern Maine.
(I have a 1500W 240V lower element in my 50 gallon WH in Florida)
