Old 11-04-13, 05:52 PM   #113
Robaroni
Robaroni's Avatar
Originally Posted by pinballlooking View Post
We are @200 mpg total miles 14,621.
Your range will go down in the winter but if you start the car precondition it this helps a lot on your range. Get heated seats then you don’t need as much heat in the car this will help winter range.
AC really does not take much range off the car they need to add a small heat pump for heat.
You have to look a high volume Volt dealers they get a bigger GM kick back and the lower volume dealers cannot come close on the price.
Mark
PB,
I've only seen one Volt here. This is a pick up truck kinda place although lots of Prius drivers.
