You might consult the manufacturer for remedy. Something doesn't sound right. Even with a tight house your combustion make up air vent should break any negative pressure at the water heater. Was the draft connector installed on the new water heater?-I've seen these left off. Is your flue vent pipe type b double wall? If not that could help increase your draft temps.
