Old 08-16-11, 11:11 PM   #10
Ryland
If you can't find a 30 amp switch then you might try a starter push button and a lower amp switch as the wear in the switch comes from making contact and again from breaking contact, or just a wire bale that holds the push button down.
I really like the idea of using scooter parts, if the motor is powerful enough of course, so you might try to find a whole scooter that has issues and rip in to that.
