Old 05-21-16, 12:39 PM   #10
stevehull
Steve Hull
There have been some very good answers here and many refer to specifics. But they miss the important point (IMHO) . . . .
Far more important are making early decisions that allow you later options for decisions.
Huh?
For example . . .
Site placement. Just one obvious issue is a south roof orientation for later solar PV and/or hot water panels. But another is placing the home in a place that allows use of an open loop geothermal heat pump (lower down pond, stream or whatever). Your site in hilly Ohio will give you this choice. You have vast quantities of close to the surface ground water. You don't need to do an expensive closed loop system.
Another is placing infrastructure for later use. Right now, you perhaps can't afford putting in PV solar panels. But you can and should put in AWG 4 stranded and insulated copper wires for each hot leg and neutral from the main panel area somewhere up into the attic area. Same with piping for the hot water panels.
You may be not be able to afford geothermal right now - or in slab thermal. But put in the larger return ducts (a major mistake of many not to do this) at the time of construction. Put the PEX tubing in the slab. For now you may not be able to hook either up. Go with a cheap propane heater for ducted heat, but it can be replaced later.
ICF, SIPS, 6 inch closed cell foamed studs, etc - doesn't really matter. Put in what your time, energy and resources allow. Buy good windows, but now is not the time for Marvin. In ten years, I expect much higher energy standards for windows anyway.
In the southern Ohio area you will need a basement (or very deep footings). Make sure to insulate the outside walls with closed cell foal sheet insulation BEFORE back filling. A major, major PITA to dig this out later.
Really look at your resources. Your wish list, if built by a contractor, is in the $150-175 per sq foot (or more) range. Do you have kids, do you have a spouse? Can they help - or are they realistically in need of your time. Doing all this by yourself can mean a very unhappy spouse with divorce - and them getting the house anyway.
What are your skill sets? Can you barter? I once got "paid" for a consult with an exchange of a band playing for my wife's birthday. The band had such a good time they stayed until 2 AM. A great trade.
Maybe you can't afford a metal roof right now - no biggie. Put on a three tab and then in fifteen years, put on a metal one.
The real key to long term energy savings is to rationally insulate and irrationally button up. Get real crazy with 6 mil plastic, foam and attention to detail. Test the house envelope for tightness while you can still seal holes/spaces. This means a blower door test before sheet rocking.
A tight house obligates you an ERV or an HRV. This is one of the essentials with insulation and minimizing infiltration.
Your description of helpers is great - but reciprocity looms. If you have them help you with a big job, are they then going to ask (rope you into) an equally large job?
Not trying to be any sage as BOY have I screwed up at times with biting off too much. We all do, but think of the big picture first. Identify options and don't sweat the small stuff - especially the stuff that can be easily replaced, painted or will need to be repaired (roofs with hail for example).
Great ideas and you have hit almost every one of them. Keep us posted.
Steve
The Following 2 Users Say Thank You to stevehull For This Useful Post:
Daox (05-24-16), jeff5may (05-29-16)
