Originally Posted by bennelson
I plan on spinning the knob around so that the locking side is on the OUTSIDE. With the top of the dutch door open, it should serve as an effictive baby gate. If I put the latch that combines both halves of the door on the inside, nobody of a decent height should fear getting locked inside.
I'm kinda making a home version of the child-locks found on the back doors of a car! The top of the dutch door would act like an open car window, allowing you to reach out and unlock from the outside if needed.
They also sell plastic door knob covers that 'slip' when you turn the knob and require you to squeeze harder than a toddler can squeeze to get them open. Also if you have a hulk baby, then you'd need them to have an adult sized hand too. This type of door knob 'child lock' is used in child care facilities(although I haven't seen this particular one) and they are successful.
Buy Safety 1st Grip n' Twist Door Knob Cover & More | drugstore.com
