Thanks for the insights! I have done a pretty good amount of homework on the Leaf. I would like the 2013+ SV or SL model for the faster charger, removed battery hump in the back, heat pump vs resistive heating, newer more efficient motor and pack chemistry update that should lead to longer pack life.
My daily commute is 7 miles to work and almost all of my trips are under 10 miles one way. The 80 miles or so of range that the Leaf has will suite my needs quite well. When it doesn't, I'll simply swap rides with my wife and take the Prius.
