I don’t know what unit you ended up with. Most units will turn on at different flow rates.
Mine kicks on at a fairly low flow rate. I use a circulating pump that gets turned on with the light switch in the bathrooms and the kitchen sink. I run it different amounts of time depending how far away from the unit.
What unit did you buy?
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
