Agree with Acuario. It can be relative easily hacked. On the orher hand, I guesse the motor spinning without any load, will probably comsume ony a few watts. All in all, Sadashi, it looks quite easy to modify the airco to an air-water heat pump. Have you got an idea about your COP? Since you haven't altered anything of the outdoor unit, I would assume you 'll have a COP close to factory spec.
