Yes, Europeans tend to leave the pumps running. I have a Viessmann boiler with a pump built in and to get the proper temp measuring of the fluid, the pump must run continuously. There is a lot of use of the Grundfos ALPHA or Wilo Stratus pumps which are ECM and tend to run 5-8w even though they can replace a 100w circ.
Zoning is more often done by zone valves and a bypass.
