I also did some quick searching for a DIY charge controller for nimh batteries and found this:
Float Charging NiMH Cells [227] | General Electronics | Electronics
It uses a 12V supply which is a bit high. I was thinking a 5-6V solar panel would be fine. I haven't looked at it quite enough to see if it will just work with a lower voltage panel. Much more searching to do.
