Interesting device. I assume you have to plug it into somewhere where you want the moisture to be dispersed?
It can't do a large area, 333 cubic feet (which is probably optimistic). So, that is a 6.5'x6.5'x8' room. However, a couple might do the trick.
It would be great to find a source of a more efficient de-humidifier. Those things really suck a ton of power. When I had mine going I think it used up as much power as my refrigerator which is 1-2 kWh per day!
