Old 07-20-11, 09:23 AM   #29
Piwoslaw
Piwoslaw's Avatar
What kind of radiator are you going to use, automotive or maybe from an old A/C or mini-split unit? What size?
I'm trying to figure out what else I'll need and I'm thinking a filter on the inlet would be a good idea. Any ideas on a super simple/cheap solution? I was thinking something like a sock rubber banded over the end of the tube, but I don't think that'll flow enough.
How about this: Take a section of pipe/tube, with diameter ~2-5 times larger than the pump's intake diameter, put a t-shirt over the bottom, set it in the sump croc and put the pump's intake inside of that. The filtering area will be 4-25x larger, so no worries about flow restriction. In fact, the pump probably wouldn't notice a finer filter.
