Old 05-14-11, 10:35 AM   #11
Ryland
Is the water coming from underground springs or something?
I like basements that have good drainage, mine has a pit that I think is for a sump pump but I just use it instead of a floor drain for the condensation from the furnace, even last summer when we had 7" of rain and the streets were flooded my basement was for the most part dry, we had about a quarter cup of water puddle up in one corner because there was standing water in the yard outside, but if you do proper drainage, foam insulation with vapor barrier slopping away from the house helps alot with water and keeping the foundation warm.
Any reason not to both use the water for grey water applications and for cooling your house? I forget who was selling them but there is a heat pump heat exchanger that goes directly to water.
