Got that link now in my favorites. Figure now is good as any to learn to work on hvac instead of having to get someone down here to fix it.
Guy says the heat pump will work until it throws that code. If its the refridgerant ill have to pressureize it and get it pressured up with some bubble soap. The manual shows all of the specs for how many ohms everything should be.
