Old 07-12-20, 09:59 PM   #6
Wanna Beco
Okay, I just installed this:
https://www.amazon.com/gp/product/B07PP2KNNH/
I needed a water heater timer. I do not recommend this one, but I am not sure I will return it. The APP just plain sucks. The only feature of the app is that you can set a time. And even that is odd. I find it odd because you have to set the stop time on the left... and then the start time on the right.
Any old used cheap timer off of CL or offer up will do, you do not need this thing. I had my hopes high because I recently (June 4th) upgraded my old outdoor sprinkler timer with a wifi enabled one. That item is a hit. The app it uses is called B-Hyve.
Since all you can really do with this new one is set a timer, then I suggest that you just get a cheapy one.
My Sense energy monitor is paying off though. Here is this months break down 83 bucks cheaper than same month last year.
Wanna Beco is offline   Reply With Quote
