There are above floor solutions that will do it however. There is a company named WarmBoard that makes a product that should work well. Their first product was a hydronic subfloor system that would get put in before the floor went down. They just started making a top of floor product that can go over the sub floor.
What makes WarmBoard good is that the entire panel is covered with relatively thick (twice as thick as other similar systems) aluminum which conducts the heat evenly over the entire surface. This product will work with heat pump hydronic feed temps. Robust insulation is still required.
Thank you for the suggestions. After reading about WarmBoard, I see some contractors are saying that it is a very expensive product at over $200 per 4x8 sheet, but the product is the cadillac of heated flooring products. They did suggest another product that was less expensive and it looks pretty good. Its
Quik Trak or from the mfg.
Uponor
There is another option, which is electric floor heating mats that you could put on the floor in the areas of your house where you spend "down time". Again, robust insulation should go under the heated area.
That is another option, thank you.
Geo
