Old 11-19-18, 09:05 AM   #8
pinballlooking
pinballlooking's Avatar
The Geothermal quote was today.
$37,095 for a series 7 water furnace
$32,324 for a series 5 water furnace
This includes no hot water.
The load calc came to 3.62 ton they would install a 4 ton unit with no backup heat strips.
(I have 3.75 ton mini splits now)
Horizontal loop 6’ deep they do not do slinky they do 3’ trench with 2 loops one on left one on right return up.
There is no way I will have it installed at this cost. It is like they calc the tax savings and add that much to the estimate.
That is about the same way the solar installed cost est. was done.
A local guy that sells used equipment will take my old equipment and install the Geo unit for 600-700 that does not sound bad but I really have no idea what it would cost.
I do all the pluming and electrical...
They just swap units.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
