For the added PCM's
The averages are 2 hrs 17m off time
26.6 minute on time
A 14% percent longer off duration with the PCM's / water jugs.
Facts: room temperature was cooler by 2 degrees c when conducting PCM tests, It may well be the measured gain is larger in this case because of it.
In the next few days i will raise my house temperature to 22 C and time the off durations again.
