Originally Posted by Xringer
The A7 brackets attach to the water in/out pipes (nipples).
I've already pulled the hot & cold nipple (PITB). I will replace the hot with the special brass nipple from the A7 kit.
The cold nipple is short and has flow restriction (small check-valve), so I'm going to replace that one with a 6" iron nipple.
Why would you use an iron cold line nipple, with the dissimilar metals problem? A ¾ x 6” brass nipple is only about $5.
