Old 08-20-09, 03:27 PM   #4
truckncycle
If you wanted to use spray in insulation and you didn't know your future electrical requirements, you could always run rigid conduit. You can get it in metal or pvc. My suggestion is to add a bunch of 20 amp outlets. You can either add a gfci breaker or control all of the outlets off of an upstream gfci. An extra outlet in the ceiling might also be good. I have an air cleaner that is attached to the ceiling. I would also run at least one 220 outlet so that you can run more powerful tools. I ran 10 gauge wire for my outlets so that I would have more power available. It was a PAIN to run since it was so hard to bend. Multistranded wire would have been easier.
truckncycle is offline   Reply With Quote
