Something interesting...
When using large amounts of leaves to compost, you need to add a material with nitrogen to get the optimum food source for the bacteria. One way to do this would be to add manure.
Composting toilets could better be called Dessicating toilets because they are designed not to compost so much as to limit odors by drying the materials. A basic design principle for composting toilets is urine separation from solids. A simple composting toilet is a pail with a strategically placed funnel to drain urine away while collecting solids. The solids are covered with peat moss or similar dry material, which helps dry them out.
The dry products of a composting toilet would be an advantageous addition to a composter using mainly dry leaves. Since the bioreactor is designed to run hot, it would likely kill pathogens more quickly than a normal manure pile. So you could solve the problem of sewage disposal, heat your home and create a fertilizing compost product for the lawn. Low impact permaculture.
Here are some interesting links I came across...
XACT BioReactor: Composting System | Cuff Farm Services
Earth Tub - Green Mountain Technologies
(WO/1999/067191) A BIOREACTOR FOR COMPOSTING
http://conference2005.ecosan.org/pre...ns/hanssen.pdf
I don't think any of these bioreactors are as good of a design as the HG 3a system.
