Old 03-11-13, 10:13 PM   #1
marx290
Vapor Compression Goon
marx290's Avatar
Send a message via Yahoo to marx290
Default Question About Filtering BBQ Propane
I'm a refrigeration hobbyist of sorts and I like using BBQ grade propane for all of my projects so far. I pass the propane through a filter when charging my systems (small stuff like dehumidifiers), and I also install an in line filter drier in the system to try to catch what water might be in there. I've noticed the stink gets filtered out too, or absorbed by the compressor oil and read in other posts that others have noticed this too.
I'm curious if anyone has a procedure for effective filtering, and maybe separating or purifying the gases in common BBQ grade propane for use in vapor compression systems?
I've been reading the thread on R-290, so maybe a link to the appropriate post?
Thanks
marx290 is offline   Reply With Quote
