Are you still working on this jj?
For the Volt packs I would recommend using a basic inverter. I like the CNBOU line. And then use a programmable charger or power supply to charge the batteries if necessary.
In a budget install it would save some trouble.
And with a pack of 8 modules. Do the BMS. The price is dropping for reliable equipment.
Current projects
Chevy Volt battery pack conversion
Blog that is down right now but will return To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Business where I sell solar stuff
[url]https://www.bobolinksolar.com
