Exalta, if you set the thermostat to 1 instead of 4, then the fridge will still need 100W max (most of the time it is less), but it will turn on less often, so in the long run will consume less energy.
You may be able to find power consumption meters locally, they do not have to be branded "Kill-a-watt". Ask around at stores with electronic doodads. Good luck!
