Old 04-18-12, 11:59 AM   #1224
Vlad
Originally Posted by pachai View Post
.....I have a couple of hydronic heat exchangers installed, so all I need to do is make cold water...
Even if the hot side will be air source for the current season, it will help.
As for the "ground" or "Water" Source...
Can you provide more details? Like heat/ cool load expected, temperature range, etc the more the better, don't worry we will read it all
Some time ago (about 2 years?), someone posted a picture of an air conditioner with a plexiglass box around the the heat exchanger, filled with water.
How critical is to have XE in plexiglass box ??
Vlad is offline   Reply With Quote
