Originally Posted by TechShop
I use a 28 gallon electric unit in my shop. The slab is heated, but I put it on 2" R-10 foam. My only hot water requirements are showers each day and a load of laundry once or twice a week.
If you have a spouse or other roommate, the 40 would be a good choice.
Nice , my tank is in the cold part of the basement with cement floor. I slid a 3/4 inch piece of plywood under it to help. Thought to myself sleeping on a sheet of plywood on a cement floor sure would beat sleeping directly on it
Cement is a hell of a heat sink it keeps sucking and sucking
The foam base is a great hack.
I was thinking a 40 would be better for a hot bath which I prefer to showers atm , the 30 may work or be border line. I did the math and 30 sounded like it might work for a tub but it would be close and may have to kept hotter to make it work , the 40 would seal the deal
