Went today and picked up a mister thing to hook to the water hose . Supposed to use 10gph. Being i am on well water it should help me out in another way . But have it spraying on the outside unit . Forgot to pick up some foam . The old foam is about hadit that i had on there. Will get a few numbers crunched tomarrow going to run it tonight see if it helps out on keeping the entire house cool or not . I am thinking my 220 volt meter is bad off so i dont really have a way to test wattage drop or anything
