Are you planning any insulation or air sealing methods in particular? I am finding that insulating a foundation and air sealing up the basement nets about a %18-25 reduction in energy usage, summer and winter. Not to mention that you can then finish the area and gain a good deal of living space.
I look forward to seeing this play out.
And you might want to check out my basement thread. There's a lot of information there put forth by me and other members.
Good luck!
EDIT: One more thing. I saw you mention running both CAT 6 and phone. No need. Just run two CAT 6 lines. You can plug a phone right into an RJ 45 jack. Then you can use it for data instead when you decide to scrap POTS and go with VOIP or a central cordless system, or both, like I did.
