Old 05-16-14, 03:20 PM   #10
pinballlooking
pinballlooking's Avatar
The Volt is also crazy conservative on how much pack capacity you use. It has a 16 or 17 kWh pack, of which you can only use 12 kWh (I believe). Reducing the depth of discharge with this technique is what gives the Toyota/Ford hybrids the ridiculously long battery life they have.
Todays Volt has a battery pack of 16.5 kilowatt-hours, of which it uses only 10.8 kWh–or 65 percent.
Daox (05-16-14)
