Old 09-22-11, 10:08 AM   #15
madmike
Originally Posted by zick View Post
How are you running your fan, is it on some kind of temp switch?
Also, do you have anything to prevent backflow so you don't loose heat at night?
I have a snap disc controller, it is a close on rise,it clicks in whenpanel temp rises to 110F and turns off when temp gets down to 90F. To prevent backflow at night I use a dryer vent, the type with 3 flaps. It isn't air tight when it closes, but it looks similar to what Cansolair uses.
madmike is offline   Reply With Quote
