Originally Posted by djastram
I put in my own geo about 9 years ago. I went with a split geo with a natural gas furnace as backup/auxiliary heat. If I had to do it over again, I would do it exactly the same.
Mine is 38000 btu (3 ton) 2 stage waterfurnace that I bought on ebay. It had been damaged in shipping, so I got it cheap enough.
I used a QT zero pressure flow center so I didn't need a flush cart. I have 3 slinky loops, 1000' long each.
I have some pictures on youtube if you would like to look at it.
Search for "geothermal heatpump install" under djastram.
I watched your video. You were in the mud also. Nice install. How has it been working. Do you have to use much natural gas heat? How many sq foot are you heating?
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
