Originally Posted by Xringer
"The U-Crown heatpump is specifically designed for Canadian weather with its 2-Stage compressor. It will keep you warm during those harsh winters with a capacity to run at full efficiency up to -30ºC outdoor temperature."
So, -22 F seems very close to the US Crown series at -20 F..
Maybe I need to find some reviews who live in the US snow belt..
I looked around some for some reviews but I did not really find any. Hopefully you will have better luck.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
