The easiest way to do heat recovery on waste water is with a vertical drain pipe. Metal dwv pipe conducts heat readily through its wall. Your recovery fluid is directed to flow around the dwv pipe. The waste water naturally sticks to the inner wall of the dwv pipe through surface tension.
