Old 02-13-18, 04:44 PM   #1934
Roostre
EcoLearner
Default Made it!
It took me a long time, but it's done. Whew.
What a great thread and resource for the DIY experimenters out there.
I found that the "Closed-Loop/Ground-Source Heat Pump Systems - Installation Guide" can be found for a bit less and ordered a copy. It is from 1988 so I hope it's not too outdated.
The section on Heating and Cooling Degree Days led me to develop this chart based on a local weather station:
Name:  Cooling vs Heating Days.JPG
My heating bill from January of 2017 shows it to be an exceptionally cold month. By back calculating the Therms it looks like the house required about 25,000 BTU/hr to maintain.
The loop is going to be the most challenging aspect I can foresee; after researching local laws it turns out that you cannot drill deeper than 30 feet without a permit from the state AND you must be a certified driller.
For a horizontal loop install we do have a decent sized backyard at about 100 feet deep and 110 feet wide. The "installation Manual" should be of great help here.
I plan to make a fusion tool fashioned after your design and spend a good deal of time practicing until my joints are 100% solid.
Thanks again for this manifesto. It excites me that such leverage exists to be harnessed by all with a little education and effort.
2013 Volt Blackbird
2013 Volt Red
(Sold 2012 Leaf)
Please don't use photobucket... there are a ton of good posts on here that make no sense because the picture is locked by photobucket's paywall.
Roostre is offline   Reply With Quote
The Following User Says Thank You to Roostre For This Useful Post:
AC_Hacker (02-16-18)
