Old 04-23-10, 09:42 AM   #23
jwxr7
jwxr7's Avatar
It sounds like your domestic hot-water doesn't come from your boiler.
You must have a gas hot-water heater.
Sorry, I should have noted in my last post that the Amtrol boilermate used for our domestic hot water does have a set temp range that it maintains in it's small holding tank, like a regular water heater, but it gets heat exchanged from the boiler, not a direct heat source. The Amtrol is one of the 5 zones running off the boiler and it holds heat pretty well. The boiler itself doesn't try to maintain a set temp for the water that's inside it.
I'm not even sure what point I was trying to make earlier .
jwxr7 is offline   Reply With Quote
