Originally Posted by Xringer
Radon is very heavy, so it mostly stays on the floor. So, to pump it out,
the air-input needs to be down close to the floor.
An oil furnace or a dryer will clean out a little of your radon. But a pump
that's designed to move Radon-Air, will do a much better job.
Wouldn't I want the air out hose exiting on the floor? My thought is to pump in outside air and have the air be removed at the floor level. This would theoretically pull out more radon, right??
