buffalopatrick you did very well on your metal roofing shingles , $2000 is a giveaway , I would install them myself and not worry about the getting the warranty , if you follow the manufactures instruction to a tee , you will be fine. Many roofing failures are due to not following the installation procedures or cheeping out on supplies, like using one layer of tar paper when they call for two etc.
