I'm not for the rocks in the walls, they will also retain the cold.
I would use stucco/plaster walls as the last wall covering, then it is in constant contact with the inside heat,as opposed to being sandwiched in the middle somewhere.
I think insulating the outside walls, from the outside of the house, under the siding would be more effective. You would get that tight seal you want out there to keep the summer heat and winter cold out of the framework/walls.
