On one of my out door lights I wanted an outlet for christmas lights to light the porch instead of the single bulb, so I added an outlet that has a three way switch, flipping the switch switches between the regular bulb and the outlet so when I turn on the switch that is inside the house that normally controls the light one or the other will come on, if you need more outlets you can always get a out door outlet box that is designed for two duplex outlets, giving you a total of 4 plugs.
I'm also of course a big fan of the twist timer switches, turn it on and forget about it because it will turn it's self off!
