I'm still waiting for my order from China. But it's only been 11 days..
Dimmable GU10 6W 3x2W LED Spot Light Bulb Lamp Warm White 3200K 450Lumen | eBay
Getting four, to replace the super hot halogen bulbs that don't seem all that safe,
because the metal fixtures are surrounded by loose cellulose insulation in a lowered ceiling.
Specifications:
Base type :GU10(30°)
Shell material :High strength glass
Heat sink material :Aluminum, zinc metal alloy
Input voltage :110V-230V
Output power :6.0W
Dimensions :80 x 50mm (Length & Diameter)
Reflector efficiency:90%
Light source :3x2W high power LED
Body temperature :<60°C
Color temperature :3000-3500K
Source life :> 50,000 hours
Safety assurance :CE & RoHS
Lumen :430-450 LM
Color : Warm White
Dimming Range:10-100%
Looking at that input voltage range, kinda makes me wonder about the power supply..?.
120vac LEDs bulbs in general.. What up with their power supplies?
Will these things run off DC too?
~~~ Edit~~~
The mailperson just dropped them off. All four are very bright on 124vac.
They will be installed this evening..
