Old 11-03-10, 01:32 PM   #8
gasstingy
I noticed that the hot water heater is a gas model similar to what I have and you say you're putting an insulation blanket around it. I keep considering that, but have been wary of how to do it correctly. How much space did you {or, will you} leave around the flue opening at the top? Did you cover over the little gas "shield" under the thermostat valve at the bottom or just leave it accessible?
