Old 03-05-11, 06:29 PM   #6
Originally Posted by NeilBlanchard View Post
I think it is a Schrader valve, then?
Also known as "American valve" or pin valve..
If there is a button on top that you can press and release to control the flow
of the R410A, then I'll bet there is a pin valve under there..
Kinda like a propane torch tank..
I look at those directions and it occurred to me, that any Air that was inside the hose,
might well end up inside your AC system.. That can't be good..
