Old 12-28-20, 08:37 AM   #36
pinballlooking
pinballlooking's Avatar
Wow, thats quite good. Do you have an idea of the kwh/mile you get vs the Volt?
The ebike differs in power used so much. Hills make a huge difference. How much you pedal makes so much difference.
@Wanna Beco
Before I bought the ebike I never even worked on a regular bike and did not know anything about ebikes. I really did not know what I wanted or how I would want to use the ebike. I just knew some features I thought were needed and I did not want to spend a crazy amount on it.
Now I see how much I am using it I am ok with changing it to be what I want.
Most people would just put the new controller on my current motor. Others have with decent results.
My side business is doing better than I thought it would so I ok with splurging a little on my ebike.
Do I need to swap out motor no. But I want to. Down the road I will probably add a second battery.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Daox (12-28-20)
