Originally Posted by Xringer
In addition to recycling the pre-heated water, some of your lost body heat would also be recycled..
Your lost body heat would only enter the wast water stream if you are taking cold baths or cold showers, since heat only flows from hotter to colder, at a rate that is dependant on the difference in temperature.
Regards,
